EcoSport Wheel Size, Bolt Pattern, Offset & Tire Information
MKVIIST
Senior Member
Staff Team
AZ
Stock EcoSport Wheel Information:
17"
16"
Size: 17x7" - 47.5mm
Weight: 22.5 lbs
EcoSport Hub Centric Ring:
63.4mm Hub Centric Diameter
Standard Fiesta Wheel Offset:
15" - 42-45mm
16" - 42-45mm
17" - 42-45mm
17x7" - 47.5mm (Included)
18" - 42-45mm
Depending on the wheel, you can go with an offset from 35mm to 47mm. The OEM EcoSport wheel weight is 22.5 pounds.
EcoSport Tire Sizes:
205/40/R17 84W (Included)
P205/40-R17 Bridgestone RE050A summer-only tires
15" Tires
175/65/R15
195/55/R15
195/60/R15
205/55/R15 (Recommended)
215/50/R15
16" Tires
185/55/R16
195/45/R16
205/45/R16 (Recommended)
205/50/R16
215/45/R16
17" Tires
195/45/R17
205/40/R17 (Recommended. This is the stock tire size.)
205/45/R17
215/35/R17
215/40/R17
18" Tires
205/40/R18
215/35/R18 (Recommended)
215/40/R18
EcoSport Spare Wheel & Tire Size:
15"x6" - 45.7mm
Tire Size 185/60 R15
Speed rating H
Load rating 84
Usage All season
EcoSport Bolt/Lug Pattern:
4x108
EcoSport Tire Pressure Sensors TPMS:
Ford Part# DE8T-1A180-AA
TX
2018 EcoSport
I was curious if anyone knows the stock rim weight on a EcoSport SE. do the 17 and 16 inch weigh the same?
XR650R
Elkhart
IN
'17 Fiesta ST
They're alloys, but they're still pretty heavy.
